CLI Commands
#Overview
If you have the Diode Client installed, in a terminal window, you can type diode to get a list of commands and diode <command> --help to get detailed help via the command line.
Name
diode - Diode network command line interface
SYNOPSYS
diode [-allowlists=] [-api=false] [-apiaddr=localho...]
[-bind=] [-blocklists=] [-blockprofile=] [-blockprofilerate=1] [-bnscachetime=10m0s]
[-configpath=] [-cpuprofile=] [-dbpath=/Users/...] [-debug=false]
[-diodeaddrs=] [-e2etimeout=15s] [-fleet=] [-logdatetime=false]
[-logfilepath=] [-memprofile=] [-metrics=false] [-mutexprofile=]
[-mutexprofilerate=1] [-pprofport=0] [-retrytimes=3] [-retrywait=1s]
[-rlimit_nofile=0] [-timeout=5s] [-update=true] COMMAND <args>
COMMANDS
bns Register/Update name service on diode blockchain.
config Manage variables in the local config store.
fetch Fetch is the command to make http GET/POST/DELETE/PUT/OPTION request through diode network.
gateway Enable a public gateway server as is used by the "diode.link" website
publish Publish ports of the local device to the Diode Network.
reset Initialize a new account and a new fleet contract in the network. WARNING deletes current credentials!
socksd Enable a socks proxy for use with browsers and other apps.
time Lookup the current time from the blockchain consensus.
token Transfer DIODEs to the given address on diode blockchain.
update Force updating the diode client version.
version Print the diode client version.
Run 'diode COMMAND --help' for more information on a command.
#Commands
Usage:
diode {options} {command} {args}
See below for options - they must be specified before the command.
Example:
diode -debug=true publish -public 80:80
#diode bns
Name
diode bns - Register/Update name service on diode blockchain.
SYNOPSYS
diode bns <args>
ARGS
-account string
Display the account information of a given BNS name
-force
Force re-registration in case of registration, even if the name is already registered.
-lookup string
Lookup a given BNS name.
-register string
Register a new BNS name with <name>=<address>.
-transfer string
Transfer an existing BNS name with <name>=<new_owner>.
-unregister string
Free a new BNS name with <name>.
EXAMPLE
diode bns -register hello-world=0x......
#diode config
Name
diode config - Manage variables in the local config store.
SYNOPSYS
diode config <args>
ARGS
-delete value
deletes the given variable from the config
-list
list all stored config keys
-set value
sets the given variable in the config
-unsafe
display private keys (disabled by default)
EXAMPLE
diode config -delete lvbn2 -delete lvbn
#diode fetch
Name
diode fetch - Fetch is the command to make http GET/POST/DELETE/PUT/OPTION request through diode network.
SYNOPSYS
diode fetch <args>
ARGS
-data string
The http body that will be transfered.
-header value
The http header that will be transfered.
-method string
The http method (GET/POST/DELETE/PUT/OPTION). (default "GET")
-output string
The output file that keep response body.
-url string
The http request URL.
-verbose
Print more information about the connection.
EXAMPLE
diode fetch -method post -data "{'username': 'test', password: '123456', 'csrf': 'abcdefg'} -header 'content-type:application/json'"
#diode gateway
Name
diode gateway - Enable a public gateway server as is used by the "diode.link" website
SYNOPSYS
diode gateway <args>
ARGS
-additional_ports string
httpsd secure server ports
-allow_redirect
allow redirect all http transmission to httpsd
-certpath string
Pem format of certificate file path of httpsd secure server (default "./priv/cert.pem")
-edge_acme
allow to use ACME generate certificates automatically
-edge_acme_email string
ACME email configuration
-fallback string
how to resolve web2 addresses (default "localhost")
-httpd_host string
host of httpd server listening to (default "127.0.0.1")
-httpd_port int
port of httpd server listening to (default 80)
-httpsd_host string
host of httpsd server listening to (default "127.0.0.1")
-httpsd_port int
port of httpsd server listening to (default 443)
-privpath string
Pem format of private key file path of httpsd secure server (default "./priv/priv.pem")
-proxy_host string
host of socksd proxy server (default "127.0.0.1")
-proxy_port int
port of socksd proxy server (default 1080)
-secure
enable httpsd server
-socksd
enable socksd proxy server
EXAMPLE
diode gateway -httpd_port 8080 -httpsd_port 443 -secure -certpath ./cert.pem -privpath ./priv.pem
#diode publish
Name
diode publish - Publish ports of the local device to the Diode Network.
SYNOPSYS
diode publish <args>
ARGS
-http
enable http static file server
-http_dir string
the root directory of http static file server
-http_host string
the host of http static file server (default "127.0.0.1")
-http_port int
the port of http static file server (default 8080)
-indexed
enable directory indexing in http static file server
-private value
expose local ports to private users. value may be <local_port>:<remote_port> or <accessible ip>:<port>:<remote_port>
-protected value
expose local ports to protected users (members of fleet contract). value may be <local_port>:<remote_port> or <accessible ip>:<port>:<remote_port>
-proxy_host string
-proxy_port int
-public value
expose ports to public users. value may be <local_port>:<remote_port> or <accessible ip>:<port>:<remote_port>
-socksd
EXAMPLE
diode publish -public 80:80 -public 8080:8080 -protected 3000:3000 -protected 3001:3001 -private 22:22,0x......,0x...... -private 33:33,0x......,0x......, -private 192.168.0.123:80:8008
#diode reset
Name
diode reset - Initialize a new account and a new fleet contract in the network. WARNING deletes current credentials!
SYNOPSYS
diode reset <args>
ARGS
-experimental
send transactions of fleet deployment and device allowlist at seme time
EXAMPLE
diode reset
#diode socksd
Name
diode socksd - Enable a socks proxy for use with browsers and other apps.
SYNOPSYS
diode socksd <args>
ARGS
-fallback string
-socksd_host string
host of socks server listening to (default "127.0.0.1")
-socksd_port int
port of socks server listening to (default 1080)
EXAMPLE
diode socksd -socksd_port 8082 -socksd_host 127.0.0.1
#diode time
Name
diode time - Lookup the current time from the blockchain consensus.
SYNOPSYS
diode time <args>
ARGS
Empty
EXAMPLE
diode time
#diode token
Name
diode token - Transfer DIODEs to the given address on diode blockchain.
SYNOPSYS
diode token <args>
ARGS
-balance
Just check the balance and quit.
-data string
Data that will be submitted with the transaction.
-gas string
Transfer gas paid to diode miner. (default "21000")
-gasprice string
Transfer gas price paid to diode miner.
-to string
The address or BNS name that DIODEs will be transfered to.
-value string
Amount of DIODEs to be transfered.
EXAMPLE
diode token -to 0x...... -value 1millidiode -gasprice 10gwei
#diode update
Name
diode update - Force updating the diode client version.
SYNOPSYS
diode update <args>
ARGS
Empty
EXAMPLE
diode update
#diode version
Name
diode version - Print the diode client version.
SYNOPSYS
diode version <args>
ARGS
Empty
EXAMPLE
diode version
#Options
Usage:
Options must be specified before the command.
Example:
#-diodeaddrs
Specify a Relay Node to connect / route through. The client’s activity will route through the Relay Node specified.
Args:
-diodeaddrs=[node IP]:[node edge port]
Example usage:
Fetch time from a specified Relay Node
diode -diodeaddrs=45.79.115.246:41046 time
Other information:
- If another client specifies a different Relay Node to connect through, that client will not be able to connect to your client.
- The [node IP] argument may also be a DNS name (e.g. us1.prenet.diode.io)
- The [node edge port] defaults to 41046 for most nodes, but some nodes may use a different port as specified by the operator
- A node’s [node IP]:[node edge port] settings can be viewed via the node system’s terminal by “sudo snap get diode-node”. The “host” parameter is the [node IP], and the “edge2-port” parameter shows the available edge ports (choose one to specify). The settings are also visible in the node’s web dashboard under “Primary Edge Address”.
- You may specify this argument multiple times to provide failover. e.g. diode -diodeaddrs=node1.mydomain.io:41046 -diodeaddrs=node2.mydomain.io:41046 time
#-bind
Bind a local port to a remote client’s Web3 port. Activity into your local port will emerge on the remote client’s port.
Args:
-bind [local port]:[client ID]:[remote port]:[udp|tcp|tls]
bind’s transport default is “tcp”
Example usage:
Bind the local port 15900 to a remote client’s local port 5900 (as often used for secure VNC tunneling).
diode -bind 15900:0x123fc642e256e1069caf9c3a812cf314c623abcd:5900
Other information:
#-debug
View more verbose debug messages in the console
Args:
-debug=[true | false]
debug default is “false”
Example usage:
Fetch time from the network while showing verbose debug messages.
diode -debug=true time
#-dbpath
Specify a different database than the default. This can be used to run multiple Diode identities via the CLI on the same machine.
Args:
-dbpath=[path to database file]
Example usage:
Use a database on the Desktop to publish content to that database’s identity via Web3.
diode -dbpath=/home/pi/Desktop/private.db publish -public 80:80
Other information:
#-fleet
Specify a different fleet address than is stored in the configuration. Useful for testing.
Args:
-fleet=[fleet address]
Example usage:
Publish content using the development fleet contract.
diode -fleet=0x6000000000000000000000000000000000000000 publish -public 80:80
Other information:
- What is a fleet contract?
- The development fleet contact (address 0x6000000000000000000000000000000000000000) is a “promiscuous” fleet contract that is available for free for all devices to use. It is also the default fleet contract used by new installations of the Diode CLI. It does not have any SLA guarantees due to low or no incentives for the network to route its traffic.
- Persist a different fleet
#-bnscachetime
Specify a name cache staleness timeout so that any subsequent use of the name (after the timeout) refreshes the name members from the chain. Useful when using BNS names as access control lists that may frequently change.
Args:
-bnscachetime=[timeout]
timeout default is “10m0s”
Example usage:
Publish private content to all clients listed as members of the “my-auth-list” name, and refresh the member list every five minutes.
diode -bnscachetime=5m0s publish -private 80:80,my-auth-list
